Unlock all clips in XDCAM Browser
COW Forums : Sony XDCAM Optical Disc & Related
Óscar Cristóbal
on Nov 27, 2012 at 8:32:48 pm
First of all, greetings to everyone:
So here's my problem; I've a Sony XDCAM HD F335, and I use XDCAM Browser to copy clips to a hard drive with CRC check. The problem is that all files imported are locked by default, and I can't seem to find a way to unlock them all at once. I can unlock each one by one double clicking it and unchecking the lock box under the preview, but that would be a nightmare. Does any of you know a way to unlock them?. Thanks for reading.
Daniel Wright
Re: Unlock all clips in XDCAM Browser
on Dec 17, 2012 at 10:33:08 pm
You could always use the Terminal.
$cd [directory containing all my locked files]
$chflags nouchg *.MXF
HTH
Óscar Cristóbal
on Dec 18, 2012 at 10:14:51 am
Thank you, but that doesn't work. It's not that the files are locked in the filesystem, it's that they're locked IN the XDCAM Browser, so I can't modify the description of several files at once. Instead, I have to unlock them within the program one by one, what makes it unuseful.
Robin Probyn
on Dec 24, 2012 at 7:52:55 pm
Are your disc,s locked when you are down loading.. with my type 1 SXS cards.. if i down load with the write record tab on.. all the files are locked in Browser.. pull the tab and they are all unlocked..
Óscar Cristóbal
on Dec 26, 2012 at 11:40:53 am
No, they aren't.
