XDCam software problem.
COW Forums : Sony XDCAM Optical Disc & Related
Wagner Wolf
on Nov 26, 2012 at 12:31:47 pm
Good morning everyone!
Sorry for my bad english.
Since upgrade for Mountain Lion, i have had several problems with XDCAM Transfer.
With XDCAM drive software 3.1.1 and 3.20, I can burn disks through Final Cut (EXPORT > Sony XDCAM), but i can't format discs with XDCAM Drive Utility.
When i try to format (Error Code: 0xA100000E) Disc access failed because the disc is damaged or disc management data was not written correctly.)
With XDCAM drive software 3.40, i can format discs through XDCAM Drive Utility, but i can't burn with Final Cut (EXPORT > Sony XDCAM) - "error writing mxf file (while checking successful write())"
Even with disks formatted with 3:40 I can burn with 3.1.1.
In Lion i can burn and format without problems, using XDCAM drive software 3.1.1 and XDCAM Transfer 2.13.
My system Macbook Pro 2012 i7-16GB , Mac Mini Server i7-16GB.
PDW-U1-USB, firmware 2.540.
Using XDCAM Transfer 2.13
I tested almost all software on the sony XDCAM site, searched everywhere, and can't find a solution.
Thank you in advance for any help, and have a good day!
Ian Cook
Re: XDCam software problem.
on Nov 26, 2012 at 3:01:45 pm
Try using Content Browser. XDCAM Transfer is discontinued and not supported under Mountain Lion.
http://www.sonycreativesoftware.com/contentbrowser
Wagner Wolf
on Nov 28, 2012 at 1:56:03 pm
Thx Ian! It works!
My problem is solved.
You saved my work, have a great day.
