XDCAM software update, FCP X Export to .mp4/.mxf
COW Forums : Sony XDCAM Optical Disc & Related
Ian Cook
on Nov 14, 2012 at 9:58:51 pm
As some users may already be aware, XDCAM Browser is getting renamed 'Content Browser.' This is because we are rolling in optional support for AVCHD and other formats going forward. Version 1.1 is currently available on the Sony Creative Services site:
http://www.sonycreativesoftware.com/contentbrowser
It will be linked to the main XDCAM downloads page shortly. The applications are more or less identical so there should be no learning curve. There are some new features but the basic workflow and UI are the same.
Users can continue using XDCAM Browser if they prefer but there will be no new development and the application has not been properly qualified for Mountain Lion or Windows 8.
Sony Advanced Pack plug-ins purchased for XDCAM Browser v2 will work with Content Browser. The serial # needs to be re-entered. There is a reminder to this effect when installing CB.
New features worth mentioning in CB 1.1:
-Export/write back support from Final Cut Pro X
Exporting to .mp4- or .mxf-wrapped XDCAM files is now supported. Via Share-->Export Media there will be an option to export using 'Content Browser Exporter.' This will open up an export dialog similar to what we have with XDCAM Browser and XDCAM Transfer, where you select the destination and the wrapper format. You can export locally or to connected XDCAM devices.
-Planning Metadata support in FCP X.
You can select planning metadata files and batch-import referenced clips using the Planning Metadata-->Import Related Clips function.
Tim Maloney
Re: XDCAM software update, FCP X Export to .mp4/.mxf
on Jan 17, 2013 at 10:39:47 pm
Thanks Ian,
I run content browser on my MB Pro lion.
F800 does not mount.. Mounts on old mbpro with snow leopard
Tips/gotchas
Tim Maloney
Managing Director
Axis Films Melbourne Australia
tim@axisfilms.com.au
Ian Cook
on Jan 17, 2013 at 10:40:10 pm
is the FAM driver installed?
http://www.sony.com/xdcam-downloads
