Retaining CC when copying clips off a disc
COW Forums : Sony XDCAM Optical Disc & Related
Michael Sacci
on Jul 14, 2012 at 9:05:55 pm
I'm using a Sony PDWU2 to bring files onto my hard drive from XDCAM HD disc. I need them to stay .mxf so I don't use XDCAM Transfer on a Mac. Right now I'm simply doing a finder drag and drop, I have both Macs and PCs.
I cannot use the disc structure in my workflow so I don't use XDCAM Browser.
When I copy the mxf over it doesn't seem to be retaining CC when the file goes out to broadcast. Is this a limitation of the PDWU2 or I'm just not doing something right?
Ian Cook
Re: Retaining CC when copying clips off a disc
on Jul 16, 2012 at 2:59:08 pm
This is a setting. In the U-1 Utility app go to User Settings and enable 'Data Item Out.' If this is de-selected any VANC metadata (captions, audio metadata, aspect flag etc) will be muted when the file is copied.
Tim Allison
on Aug 2, 2012 at 3:58:24 pm
How does this work with an F75 deck? Is there a similar menu item to check or uncheck?
Ian Cook
on Aug 2, 2012 at 4:21:58 pm
No, no such menu on the 70/75. If the file has compliant captions they should be retained when the file is moved. The only VANC setup on the 70/75 is for recording (setting the VANC line and DID/SDID values)
