Copying individual clips
COW Forums : Sony XDCAM Optical Disc & Related
David Brown
on Feb 14, 2011 at 9:21:35 pm
When I want to copy a disc, I hook up my U1 or PDW700 to my computer, open up the disc, copy all the files and drag them to the hard drive I am copying onto.Now I need to make a copy of one or two clips from an optical disc and I don't want to copy the whole disc. What do I need to copy?
David Brown
Ian Cook
Re: Copying individual clips
on Feb 14, 2011 at 10:37:13 pm
Hi David,
The Full resolution files live in the CLIP folder. If you copy the MXFs you need from here you should be good to go.
Make sure you are copying from /CLIP and not ProAV/CLIPR (this folder might not even be visible depending on settings...it's where the raw files reside)..
Best,
Ian
Ian Cook
Sony Broadcast and Professional Company
David Brown
on Feb 14, 2011 at 10:43:56 pm
Thanks, Ian. I'll give this a try later.
