Letterbox composite output from PDW700
COW Forums : Sony XDCAM Optical Disc & Related
David Brown
on Nov 8, 2010 at 3:34:07 pm
I have some HD material that I want to burn on a DVD. How do I output letterboxed composite? "Squeeze" and "Crop" do what they suggest but I don't find a "letterbox" menu choice.
On Sony's product detail page for the 700 http://pro.sony.com/bbsc/ssr/product-PDW700/ it says:
Aspect Ratio Control The following conversion is possible in recording mode: Upconversion from SD to HD In the downconversion process from HD to SD, Squeeze / Edge Crop / Letter Box are available. In the upconversion process from SD to HD Squeeze / Edge Crop / Letter Box are available
db
David Brown
dbsouth@tampabay.rr.com
Ian Cook
Re: Letterbox composite output from PDW700
on Nov 8, 2010 at 5:03:33 pm
Hi David,
Letterbox support was added in a software update and has to be enabled in a separate menu. Go to Menu O-29 (the "Select Function" menu) and under "letterbox" select "enable." After you do this it will be added to the list of output choices in the Output 2--> Down Conv menu.
Note that this is not available in 24p, which can only be output in Squeeze or Crop...
Best,
Ian
Ian Cook
Sony Broadcast and Professional Company
David Brown
on Nov 9, 2010 at 10:37:41 pm
db
David Brown
