PDW-F800 Can't Record PROXY files / format USB device
COW Forums : Sony XDCAM Optical Disc & Related
Daniel Andreas
on Oct 11, 2010 at 2:35:50 am
Manual tells me to format USB drive as follows:
Go to Menue Operation 33 etc -- problem is the Operation menue on my camera only goes to 32!!!
I used to be able to go to O33 but now I can't.
What can I do???
I previously went to 0-07 to ENABLE USB
Daniel Andreas
Director of Photography
Los Angeles
DVW970 DigiBetacam PAL
SDX900
HDX900
Ian Cook
Re: PDW-F800 Can't Record PROXY files / format USB device
on Oct 11, 2010 at 1:54:45 pm
Hi Daniel-
Can you get there from the TOP menu?
Press and hold the rotary wheel while you toggle the menu, then navigate to File menu pg 10.
After formatting the stick, enable USB recording in Operational menu 33.
Ian
Daniel Andreas
on Oct 12, 2010 at 3:01:20 am
File Menue Pg. 10 is Memory Stick format -- this is about USB drive....
which is O-33 which is not accessible from my camera all of a sudden -- stops at O-32
no idea why....
Daniel Andreas
Los Angeles
SDX900
HDX900
Ian Cook
on Oct 12, 2010 at 1:25:47 pm
Sorry, does the (same) Top Menu procedure allow you access to O-33?
Daniel Andreas
on Oct 13, 2010 at 2:44:51 pm
it only goes to O-32, but turns out that O-32 has all those settings that are supposed to be in O-33, no idea how that happened but at least now I can record onto Memory Stick
Just not sure where to find the viewing software thats supposed to be online for free by Sony.
any links / tips?
Daniel Andreas
Los Angeles
SDX900
HDX900
Ian Cook
on Oct 13, 2010 at 2:51:09 pm
The Windows MXF viewer can be found here:
https://www.servicesplus.sel.sony.com/sony-software-model-PDZVX10.aspx
Re the menu, can you tell me exactly what you see when you toggle the menu on? IE what is the 'home' screen?
Thx
