ALAC is a little over rated
COW Forums : Sony XDCAM Optical Disc & Related
Aaron Accione
on Jun 16, 2010 at 9:08:43 am
I have an F800 and PDW700 and a 2- Fujinon HA18x7.6BERM-M58B lenses. I have tried both lenses On the 700 I can see no effect when we Switch the alac function on/off in the cameras maintenance menu. I have tried shooting metallic objects, varing degrees of overexposure, white backgrounds, over lighting and the ALAC just seems to have very little effect in cleaning up the images.
The f800 shows a minor bit of clean up but not much.
Oh well, I shoot soft lit interviews anyway usually @ F1.8 wide open and don't really need ALAC anyway.
New Cameras New Lenses and yes Version 4G.
Patrick McCarty
Re: ALAC is a little over rated
on Feb 1, 2011 at 6:20:46 pm
Your lens may not be compatible. Look on the under side of the lens motor and you will see a number followed by a letter, If it is not 4G or higher, you will need to upgrade your lens.
© 2018 All Rights Reserved
