XDCAM HD Import Issue & FCP 7
COW Forums : Sony XDCAM Optical Disc & Related
Wayne Carey
on May 20, 2010 at 1:47:26 pm
Hey gang,
To all of you that use XDCAM HD... I'd like to see if you are getting this same issue that I am seeing.
We'll use our XDCAM HD decks to log footage and save that back to disk for future reference. Its much easier to just import the clips you need and then re-capture those clips into any format that you are using. Yes, I know... FCP can mix formats, but, at the cost of render time. We are trying to save render times and disk space, too.
When you delete the media and change the audio to meet the needs of you project, then you try to Batch Capture these clips, you get the Log and Transfer window, not the Log and Capture dialog that you get with ALL other formats when doing this.
I want to see if everyone using XDCAM HD is having this same issue.
By the way, I'm on Snow Leopard 10.6.3 using Sony's XDCAM Transfer 2.12.0
Wayne Carey
Schazam Productions
© 2018 All Rights Reserved
