MKH-416 on a PDW-700
COW Forums : Sony XDCAM Optical Disc & Related
Jason Brown
on Mar 18, 2010 at 8:13:28 pm
The hole in the viewfinder microphone holder is larger than my Sennheiser MKH 416...what do you guys use to adapt?
-Jason
Steve Wargo
Re: MKH-416 on a PDW-700
on Mar 22, 2010 at 5:17:04 pm
They make some rubber spools that increase the diameter. Check with Sennheiser first. In a pinch, we use carefully trimmed gaff tape. This is a short term fix only as the tape glue will eventually become a fluid and then.....
Steve Wargo
Tempe, Arizona
It's a dry heat!
Sony HDCAM F-900 & HDW-2000/1 deck
5 Final Cut (not quite PRO) systems
Sony HVR-M25 HDV deck
2-Sony EX-1 HD .
Ask me how to Market Yourself using Send Out Cards
Curt Pair
on Mar 30, 2010 at 3:20:05 am
I would do the same thing as Steve... TYPICALLY, the camera comes with a rubber grommet looking thing to achieve this... check the box. If not, MOST mic's do too! If you've lost yours, call your audio equipment dealer too. They can sell you a new one for a nominal fee.
If that's too expensive try tennis handle tape, or something similar... a few wraps of that, and you're set...
Curt
Curt Pair
Picture This Productions
Sony ICE Team
F900/F800/F350/PDW700/EX1/EX3/D790/D600
Adobe Premiere Pro CS3 HD/Matrox
Phoenix, AZ
Jason Brown
on Mar 30, 2010 at 1:04:22 pm
Camera came with a rubber spacer that I'm *guessing* is for the mic spacer.
The Sennheiser mic didn't come with any spacer, and I called and they don't make one. I'll probably use some tape to space it out, but it's a pretty large discrepancy in size, so it will be wrapped up pretty big.
-Jason
Jason Brown
on Apr 20, 2010 at 6:55:52 pm
Just got back from NAB and found that this:
http://www.calumetphoto.com/item/SZ2268/
is what Sony is using on their 21mm diameter microphones to fit in their mic holders.
-Jason
