PDW 700 & Denecke SB-T
COW Forums : Sony XDCAM Optical Disc & Related
Thomas Kist
on Mar 4, 2010 at 11:08:55 pm
Does anybody know the correct settings for an Denecke SB-T timecode generator in combination with a Sony PDW-700 XDcam HD camera?
the gen lock settings keep meshing up the camera sync
Thomas Kist
Freelance D.o.P
Amsterdam,The Netherlands
PDW-700,EX-3&Letus,FCP 6
http://www.thomaskist.com
Curt Pair
Re: PDW 700 & Denecke SB-T
on Mar 30, 2010 at 12:54:48 am
Hey there! I OWN three SB-T boxes with my F800s! What frame rate and frequency selection are you trying to do? (my guess is this is where you're getting jammed up!) I typically shoot EVERYTHING in 24p/1080.
Here's what I can tell you:
24p: Dial switch to 4, dip switches to 01
Even though the F800 is a PROGRESSIVE frame, it still needs to be set to segmented... it's on Denecke's site.
30p: Dial switch to 1, dip switches to 00
59.94i: Dial switch to 7, dip switches to 00
720p stuff:
I've only done this a few times... I think it's the following, however, I could be wrong!
59.94p: Dial switch to 0, dip switches to 11 (
Remember, all of the stuff in 720 is "truly" 59.94p by format... even though "frame rates" say otherwise... typically, cameras "flag" frames to be dropped in post to look a particular frame rate!)
I had trouble with mine on the first run! I called Denecke, and then it's been a piece of cake since. Don't be afraid to reach out to them for help!
Curt
Curt Pair
Picture This Productions
Sony ICE Team
F900/F800/F350/PDW700/EX1/EX3/D790/D600
Adobe Premiere Pro CS3 HD/Matrox
Phoenix, AZ
