800 vs 700 daylight balance
COW Forums : Sony XDCAM Optical Disc & Related
Michael Brennan
on Nov 30, 2009 at 11:39:57 pm
Im interested to learn of the difference between these two cameras when shooting side by side in daylight.
Presumably there must be some difference between electronic 5600k balance of the 700 and preset optical filter balance of the 800 in daylight?
Ill need to intercut between the two.
Job/kit is abroad so I cant test just yet.
Mike Brennan
john sharaf
Re: 800 vs 700 daylight balance
on Dec 8, 2009 at 7:59:29 pm
Mike,
I have both 700 and 800 and despite electronic daylight control in 700 and optical filter in 800, I get excellent match. Of course I use a DSC chart, waveform/vectorscope and RMB-750 controls to adjust and confirm, but these cameras can easily be made to make identical pictures.
JS
Alister Chapman
on Jan 24, 2010 at 9:22:29 pm
You can set the F800 to electronically correct rather than optical if you choose. Theory goes that electronic correction is actually preferable as the camera is native tungsten so when balancing for daylight the normally noisy blue channel gain gets reduced resulting in a cleaner picture. Also gives constant gain across all white balance settings.
Alister Chapman
http://www.xdcam-user.com
