XDCAM Logs without Thumbnails?
COW Forums : Sony XDCAM Optical Disc & Related
William Campbell
on Nov 13, 2009 at 4:38:48 am
Is it possible to print logs from the Sony XDCAM transfer software without the thumbnails? The clips names and logging info would be just fine. With the thumbnails a disk might produce 30 pages. We don't need the thumbnails.
Mitch Jordan
Re: XDCAM Logs without Thumbnails?
on Nov 17, 2009 at 6:08:09 pm
Have you tried changing the view mode to list before you print?
William Campbell
on Nov 17, 2009 at 8:29:05 pm
I changed the view to list but the print from Transfer still gives the thumbnail.
Working with your list tip I discovered you can select all and copy the list to Excel. Using the list columns in Transfer you can get rid of the logging info you don't need. Drag the columns in the order you want like in FCP and copy to Excel. I'm making a template in Exel with first few lines for Disk, Location, Subject, Audio. Then just paste the data from the list in transfer.
