PDW 350 vs EX-3
COW Forums : Sony XDCAM Optical Disc & Related
Chuck Farace
PDW 350 vs EX-3
on Oct 8, 2009 at 2:21:35 pm
How does the PWD350 compare to the EX-3 or Panasonic HPX300 aside form more cost? I would be using this for sports off sticks primarily some corp video work as well. Most going to DVD or Web right now. Thank you.
Alister Chapman
Re: PDW 350 vs EX-3
on Jan 17, 2010 at 8:00:37 pm
The PMW-350 is quite a bit better than the EX3. For starters there is the B4 2/3" lens mount so you have a vast range of lenses to choose from. It is more sensitive and gives a cleaner, less noisy picture. If you want SD you can add the SD recording option. You also have 4 channels of audio
The EX3 is capable of producing very good pictures, the 350 takes things up another notch. If your doing corporate work the full size camera "look" won't harm your business image. When working on sticks I find a full size camera easier to work with.
Alister Chapman
http://www.xdcam-user.com
