Gary Adcock, PDW800 review errors
COW Forums : Sony XDCAM Optical Disc & Related
steve phillipps
on Oct 6, 2009 at 5:10:22 pm
There is a review on http://www.reel-show.tv by Gary Adcock on thr PDW800. Just gone through the first bit and there are 2 errors already. He says that the PDW700 will do over and under cranking, and that the XDCam codec is I frame. Correct me if I'm wrong but neither of those is correct.
Steve
steve phillipps
Re: Gary Adcock, PDW800 review errors
on Oct 9, 2009 at 8:30:40 am
The video appears to have the errors edited out now - thanks!
Steve
Michael Palmer
on Nov 23, 2009 at 10:44:51 pm
Mpeg-2 has the ability to use inter-frame and intra-frame methods for compression. The XD Cam HD codec is inter-frame (Long GOP) which is extremely efficient at this level. The Torino encoder found in most Sony HDV and XD Cam units can provide i-frame @100 Mbps, and if you want this ability you can purchase the Convergent Design Nano Flash SDI/HDMI digital recorder and set the bit rate all the way up to 280 Mbps.
Good Luck
Michael Palmer
