HDW-D1800 setting for Dolby E
COW Forums : Sony XDCAM Optical Disc & Related
Anthony Paremal
on Jul 25, 2009 at 2:19:08 pm
Hope this is the correct forum. If not please let me know the correct forum to post.
I need advice on how to setup the Sony HDW-D1800 for Dolby E.
This is the current setup.
1. Audio in Pro Tools. 5.1 audio at 48hz 29.97 fps.
2. All the 6 channels are connected to the Dolby E Encoder.
3. The Sony HDW-D1800 deck is set to 59.94i.
4. The audio is going to aes 3 and 4 on the deck.
5. The audio 3 and 4 is set to data. The Non-audio flag is set too.
6. Video ref of 29.97 is going to the pro tools, encoder, deck, decoder.
7. Audio is going to 3 and 4. The level meter is full.
8. The 3 and 4 output on deck is connected to decoder.
9. Deck is set to EE.
10. There is output on the decoder. Here is the big BUT. The audio can be heard but it sounds like bubbling under water. The music can be heard but with the bubbling effect. The error led on the decoder is lit and flashing red.
Just cannot figure out what we are doing wrong. We did the following to test if the encoder and the decoder is set correctly. The output of the encoder was connected directly to the decoder. Bypassing the deck. The decoder is working great. No error. Everything is sweet.
Next we recorded on to tape and played back and still error on the decoder. The audio from tape through the decoder is still sounding like under water. The bubbling effect.
What am I doing wrong? Please please advice on how to setup the HDW-D1800 to record Dolby E.
P.V.Anthony
Anthony Paremal
Re: HDW-D1800 setting for Dolby E
on Sep 10, 2009 at 4:40:46 pm
Yes got is solved.
The main problem was the setting for the external ref. I set it to HD when it should be SD. This is even when doing a HD job because the extrenal ref is in SD.
Here is what was done in detail.
http://www.mindmedia.com.sg/about/wiki/wiki/dolby-e-setting-on-sony-hdw-d18...
P.V.Anthony
Thom Obarski
Re: HDW-1800 setting for Dolby E
on Jan 17, 2011 at 8:57:54 pm
Hey, i know this post was several years ago but it really helped me today!
I'm about to do a dolby E layoff on HDW-1800 (not D) supposedly it can handle it, with software encoded dolby E stream thru final cut.
After much searching I've found that to get to data mode for tracks 3&4 is buried in maintenance menu M37->372 Non-Audio Input; from which you can set if you want tracks to be audio, burst, or continuous; kind of combining your steps 5 & 6.
Just thought I'd mention it if you wanted to update the data on your mindmedia site; as that was the only helpful piece of information i found on the interwebs!
Also in my workflow i'll be changing REF to input and audio source to sdi 3&4 rather than AES but will be changing ref input from HD to SD as you said that was your biggest problem; will write back later today with the results!
"This is post, you can't fix it after this."
Thom Obarski
on Jan 18, 2011 at 2:25:01 am
so yeah looks like everything goes fine on the layoff, then i go to capture the project just to test to see if everything is working ok and i'm getting super stuttery audio and crc errors on almost every frame; any thoughts?
