1080i59.94 Down to 1080p29.97
COW Forums : Telestream
Daniel Skrobowski
on Jul 25, 2014 at 5:40:41 pm
This is probably a newb question, but I need to ask it anyway.
I'd like to use Wirecast to capture capture 1080p video to a disc using a 1080i59.94 output from a HD-SDI switcher.
What is the best way to do this in Wirecast?
I guess I'm a little bit confused about the rules when using a 1080i59.94 signal to get a 1080p signal. I'm guessing that my file output settings would be 1080p29.97. But, do I need to manage the de-interlacing settings at all? Is that little selection box that's by itself in the Wirecast settings box that says "deinterlace" the only thing that I need to worry about?
All tips are appreciated.
Thanks.
Craig Seeman
Re: 1080i59.94 Down to 1080p29.97
on Jul 25, 2014 at 7:44:41 pm
You can use "blend" in Wirecast Source Settings for the device coming in.
Then just record using 1080p29.97. On Mac I'd use ProRes. On Windows I'd use x264 .mp4 at a high data rate.
