Using a Iphone as a camera source. Possible?
COW Forums : Telestream
John Mark
on Sep 7, 2013 at 2:55:54 am
Will it be possible to connect a iphone to the lasted wire-cast software?
Thank you.
A News Graphic Lover
Craig Seeman
Re: Using a Iphone as a camera source. Possible?
on Sep 20, 2013 at 1:37:29 am
It depends on what you're trying to do. Do you mean the iPhone camera?
In the upcoming Wirecast 5 if you send the iPhone to a server you can use the streaming URL in the new WebStream plugin.
http://www.telestream.net/company/press/2013-09-12.htm
Web stream plugin allows an IP or web-based live feed to be used as a source, supporting RTMP, RTSP, MMS or HTTP as input sources into Wirecast. This enables a Wirecast live stream to be used as a source in another Wirecast.
John Mark
on Sep 22, 2013 at 12:33:05 am
[Craig Seeman] "Do you mean the iPhone camera?"
Yes the Iphone camera itself. Also, what program would I have to use to integrate the iphone into wire-cast 5?
Craig Seeman
on Sep 24, 2013 at 7:25:48 pm
You'd need to send the iPhone to a server such as Wowza for example.
It might be possible to send to one of the well known CDNs such as Ustream if you know the trick on getting the stream link directly.
