Camera coming up as black screen
COW Forums : Telestream
Drew Delany
on Aug 9, 2013 at 2:07:54 pm
Hi Guys,
Got a problem with a set-up. Place I work has just bought Wirecast and is trying to connect their Blackmagic Cinema Camera to it via thunderbolt to use for live streaming.
I installed the drivers for the camera and Wirecast has it in the add source menu but when I add it it comes up black. Camera is on and showing something, works with media express and ultrascope, but not in wire cast.
I'm using a brand new macbook with OSX 10.8.3, Wirecast version 4.3. Camera is set to ProRes 25fps as is wirecast and all other inputs work.
Any thoughts??
Cheers,
Drew
Craig Seeman
Re: Camera coming up as black screen
on Aug 9, 2013 at 2:30:13 pm
I had talked to Blackmagic about this awhile back. They'd have to make a driver to support it so they said at the time.
You should certainly be able to use the camera's SDI out and go into the Mac with a Blackmagic UltraStudio MiniRecorder.
BTW I'd strongly recommend staying current.
OSX 10.8.4
Wirecast 4.3.1
Blackmagic driver 9.7.7
