Wirecast 2 Camera Audio Feed
COW Forums : Telestream
Lindsay Barker
on Aug 16, 2010 at 11:56:32 am
Hi All,
I have a question regarding wirecast and live streaming audio from 2 cameras.
If I have 2 cameras, both firewire input into a macbook pro (one through firewire port and one through express card slot), is it possible to tell wirecast to only take the audio feed from 1 camera? If so how?
I want to be able to switch from a looping quicktime playing before a 2 camera interview.
I have 2 mic feeds going into camera 1 for the audio, so I don't want to cut to camera 2 during the stream and have no audio.....I need to also be able to switch back to the quicktime audio afterwards.
Lindsay
Jeff Mack
Re: Wirecast 2 Camera Audio Feed
on Aug 16, 2010 at 6:37:26 pm
Go to Layout and select Layer Panel. There you will see a list of layers pop up on the left. Select audio tab and all of you audio sources will show up. Then select the audio layer for that camera.
Jeff
