output sizes in wirecast
COW Forums : Telestream
Camilo Ramos
on May 4, 2010 at 2:18:56 pm
I am trying to create some videos for on-demand viewing. I haven't been able to record on sizes or aspect ratios other than 4:3, 16:9, or HD. Can anybody please advice on how can i create or record a movie that's for example, 700 x 500 - squared pixels? I need this in order to include the video inside a flash page that has already been designed.
Thanks in advance...
Craig Seeman
Re: output sizes in wirecast
on May 4, 2010 at 10:00:48 pm
You can set the frame size to whatever you want in the Broadcast settings.
The issue you'll run into is that the input aspect ratio frame sizes are based on video frame sizes.
Output can be anything you want though.
Camilo Ramos
on May 6, 2010 at 12:50:26 pm
Thanks... So in other words, if I choose a size other then the usual NTSC/PAL - SD/HD formats, the result will be distorted ?
Craig Seeman
on Jun 18, 2010 at 3:45:05 pm
There's too many variables on that to say for sure.
You're confusing input "canvas" with encoder output.
Wirecast will output whatever frame dimensions you set it for in the encoder.
It's up to your Flash player to interpret Wirecast output.
