wirecast won't recognize my Camera
COW Forums : Telestream
Aaron Clark
on Apr 13, 2010 at 6:11:18 pm
Will some one please help me? I can't seem to get my sony HDR-FX1 camera to be recognized by wirecast. I am using a firewire cable to connect my camera to my computer and there is no video getting to wirecast. I know it can't be my camera because i get a live feed perfectly when i use Final Cut Pro. I have tried everything i can think of and im frustrated. If some one could tell me step by step how to fix this that would be great!
Craig Seeman
Re: wirecast won't recognize my Camera
on Apr 13, 2010 at 6:23:16 pm
You really need to detail exactly what you've done. I'm not sure what "everything" you tried nor what you're seeing or not seeing.
Make sure you have NO OTHER video apps running or they may grab the camera, including Quicktime and Final Cut. Camera can only feed ONE program. Make sure the camera is selected in Device Manager and check in Asset Manager as well.
Aaron Clark
on Apr 13, 2010 at 6:38:14 pm
wirecast is the only thing i have running except for Safari. I have my camera connected and have tried turning it on before and after i started the wirecast program with no results.
The Camera is not listed in the Device Manager or Asset Manager.
Craig Seeman
on Apr 13, 2010 at 6:47:55 pm
It must be turned on before starting Wirecast 3.5.7.
Try testing in Quicktime 7.6.x using File/New Movie Recording to see if your camera shows there.
Aaron Clark
on Apr 13, 2010 at 6:54:47 pm
Thats weird. It does not show up in the quick time File/New Movie Recording ether. What does that mean?
Craig Seeman
on Apr 13, 2010 at 7:05:45 pm
If Quicktime can't see it, it means you may have a system problem which might involve Quicktime. Make sure you're using Quicktime 7.6 and not Quicktime X.
Double check Quicktime Preferences and click on the little Camera icon (says Recording under it) and see if the camera shows up at all as a selectable video source.
Aaron Clark
on Apr 13, 2010 at 7:04:52 pm
Ok it is working now. It was a bad firewire cord. i switched it out with a deferent one and now its working fine
Craig Seeman
on Apr 13, 2010 at 7:30:46 pm
Sometimes they can go intermittent.
Jeff Mack
on Apr 15, 2010 at 10:15:23 pm
IF YOU COOSE TO DOWNCONVERT IN YOUR CAMERA WHILE YOU ARE CONNECTED VIA FIREWIRE, YOUR SYSTEM WON'T RECOGNIZE THE CAMERA. TURN OFF THE CAMERA, UNPLUG THE FIREWIRE, PLUG THE FIREWIRE BACK IN AND TURN THE CAMERA ON. SHOULD WORK THEN.
JEFF
christopher rogers
on Jun 18, 2010 at 3:03:35 pm
Aaron,Im looking to buy wire cast for my qosmio 808 adobe cs5
and cannon 5d mk 11 anything i should know in vegas ? cheers kit rogers
Craig Seeman
on Jun 18, 2010 at 3:40:58 pm
Camera needs to have a live out. What is the live out of the Canon 5D? HDMI? You'd need an HDMI input device. They're hard to come by for laptops. Desktop computers often use Blackmagic cards. All this is unofficial territory until Telestream tests for upcoming Wirecast 4 compatibility.
