turning off vitc
COW Forums : Sony SRW Decks
Tom Dempsey
turning off vitc
on May 28, 2009 at 2:24:55 pm
i am having trouble turning off vitc timecode on a srw 5800. we attempted it several times
and the machine says it is off. however, when i'm back in is still being read.
any tricks, etc?
Mark Spano
Re: turning off vitc
on Jun 1, 2009 at 5:30:02 pm
If you're playing back videotape with VITC burned in, it will output with the video regardless of whether the machine is told it should use it or not. What you need is to blank the lines associated with VITC, or tell the Avid to ignore it. To blank the lines at the machine, go to Setup, VTR Setup, and in there will be a setting called Blank Line. It is normally set to "All Through" which will pass the lines through to the machine's outs. You can either select the VITC lines to be blanked or choose "All Blank" and it should cover over those data lines with video black on output.
© 2018 All Rights Reserved
