adjusting monitor audio independent of line audio?
COW Forums : Sony SRW Decks
Mike Langevin
on May 27, 2009 at 3:29:50 pm
simple question, but I can't find a simple answer.
Is there a way to adjust the monitor (XLR) outputs on the deck without effecting the actual levels?
I'm loading a show via HD SDI with embeded audio, but I need to pull a simple DVD screener at the same time. If I don't adjust the playback audio levels, the DVD blows out, but if I do.... well then my audio isn't coming in where it should be, which is a bigger mistake.
sorry if that was too wordy. anyone?
