NO PLAYBACK; Warning 53
COW Forums : Sony SRW Decks
Chris Liddell
on Apr 12, 2009 at 12:57:57 am
Hello, I'm hoping someone familiar with the 5800 deck can explain what this warning is actually referring to and how I can adjust the system settings of this hire deck so I get playback asap.
WARNING 53 - SYSTEM MISMATCH - The tape cannot be played with the current system settings.
This is my first experience with this deck so my inability to get a single frame of playback may not be caused by this 53 mismatch, but it's the only lead I have at present.
My source was filmed on Sony F35 @ 4:4:4 at times 25PsF & 50PsF... I only need playback at 25fps to capture (all 50PsF footage will be captured "slow-mo') and am running out of time!!!
Any insight is greatly appreciated
Chris
Chris Liddell
Re: NO PLAYBACK; Warning 53
on Apr 12, 2009 at 6:30:49 am
Ok, well I've got it sorted.
I found my way into the System Settings and aligned all SYS setup to the 25PsF 1080 4:4:4 SQ as per my footage
All working splendidly now
Cheers
