Recording from SRW-5800 to DVD..??
COW Forums : Sony SRW Decks
Ray Brown
on May 15, 2013 at 5:39:40 pm
We have both; and SRW-5800 and an SRW-5500. At present our workflow is to patch the 5800 to the 5500 and from there into the DVD player to record a clean copy before sending the tape out to the broadcaster. I'm told there is no way to record directly into the DVD deck straight from the 5800 without the addition of the SD conversion card ($15,000 or so).
Does anyone know of a reasonable work-around or am I making a proposal to purchasing..?
Please and thank you for any advice you may offer.
Cut_it_up/clean_it_up!
Joseph Owens
Re: Recording from SRW-5800 to DVD..??
on May 17, 2013 at 8:08:35 pm
[Ray Brown] "no way to record directly into the DVD deck straight from the 5800 without the addition of the SD conversion card ($15,000 or so). "
You can buy a lot of other things for $15K.
Teranex, for example... you could buy 5 of them and achieve more or less the same end result.
You could also pipe the 5800 through a Kona or Decklink card to do the down-conversion...
couple of suggestions off the top of my head...
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
