Mastering 1080/24p to SRW5800 will make it PSF ???
COW Forums : Sony SRW Decks
Anhtu Vu
on Jan 9, 2013 at 1:03:37 am
I have a QT in Prores HQ, 1920 x 1080 @ 24 fps.....and yes true 24 fps (it was an output from a DCP)
I need to convert it to 24 PSF as our Christie only accept 24PSF. If i understand correctly, Sony HDcam 5800 only works in PSF...can i make an HDcam master with my SRW5800 from a FCP7 timeline in 24p ??? If so will the HDcam master be automatically in PSF ??? thx
Mark Spano
Re: Mastering 1080/24p to SRW5800 will make it PSF ???
on Jan 11, 2013 at 5:14:51 pm
You can not send a 24.0p SDI signal to an SR deck and have it record as 24.0sF. However, you can easily convert 24.0p to 24.0sF from FCP with the right output interface. What is your video output interface? Usually they provide some easy setups for FCP, but if not, you should just check (in FCP) under View>Video Playback. If 24.0sF is there, then you can set your sequence to 24.0p, set Video Playback to 24.0sF, and send that over SDI to the deck.
