Setting the SR 5500 SD SDI OUTPUT
COW Forums : Sony SRW Decks
jay agoglia
on Jun 13, 2012 at 8:16:40 pm
Hi Cow,
I am seeking assistance in setting the internal SD format to the corresponding SD SDI output of the SR.
I am looking to do a standard edge crop down-convert feed of a standard 1080I 29.97 (59.94) input or tape source.
Please point me in the right direction or menu location .
thank you all!
Joseph Owens
Re: Setting the SR 5500 SD SDI OUTPUT
on Jun 13, 2012 at 8:41:27 pm
The SD SDI output BNC connectors at the lower right of the back plane (next to the AC connector) are always Standard Def (downconvert), and the various aspect ratios and crops are defined in the setup menu item 930 (Downconverter Mode). The preview output should reflect your setting on the main menu on the front panel. The system configuration will also have to be 1080i5994 unless you are working with a Frame Rate Converter-optioned machine and a native tape that is other than 5994.
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
jay agoglia
on Jun 26, 2012 at 5:53:43 pm
I realized I never said Thank You!
This worked of course.
thank you!
