Setting the SR 5500 to receive TC from an HD Vela decoder card
COW Forums : Sony SRW Decks
jay agoglia
on Jan 17, 2012 at 7:28:36 pm
To the Cow:
I need some help with the HD cam sr settings and TC info:
Background:
I would like to print a file based playlist of spots to HD SR Tape. I need every file to start 01:00:00:00
I believe the most efficient way for me to do this is:
set up the virtual time code field in my Vela decoder card (play advantage plus) to 01:00:00:00 which will play each file at that specific TC... (great!)
Questions/Help:
I understand that SR 5500 will take TC in two standard ways:
VITC through SDI
LTC through XLR
is the above true or is there more?
Does the SR 5500 support VITC per RP188....what is RP188?
Should I just use the breakout cable that will run from the vela card to the HD SR transferring LTC input using an XLR connector?
I hope the cow can shed some light on TC and the SR for me.
thanks
Jay
