10bit log to Lin
COW Forums : Sony SRW Decks
Mathieu Marano
10bit log to Lin
on Feb 17, 2010 at 6:51:56 pm
Hi, I will receive a HDCAM SR tape recorded at 4:4:4 10bit log. I need to edit offline in a AVID MC w/adrenaline. Is there a way to capture a linear output out of a SRW-5500? Can the SRW-5500 do a realtime LOGtoLIN?
Mathieu Marano
online editor - motion graphics - Post-prod director
Directeur technique de post-production
Le Bureau de post production
Administrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org
gary adcock
Re: 10bit log to Lin
on Feb 17, 2010 at 9:12:55 pm
[Mathieu Marano] "Hi, I will receive a HDCAM SR tape recorded at 4:4:4 10bit log. I need to edit offline in a AVID MC w/adrenaline. Is there a way to capture a linear output out of a SRW-5500?"
not really.
while the deck can do a conversion to single link, it will still be a log signal, even if the conversion boards are installed.
I do this ONSET using a cine-tal monitor and Irida Speedgrade Onset to apply a live 3D LUT to the image as it is passed thru the Cine-tal monitor, where as the HDLink only allows for a much less controlled 1D LUT.
You could run as a one light thru davinci to achieve that same effect.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, IL
http://blogs.creativecow.net/24640
http://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
Mathieu Marano
on Feb 18, 2010 at 1:57:38 am
Well it look like the only HD deck that can do this is the SRW-1. It can load an ARRI log to lin app to make a LIN DigiBeta for offline editing.
Mathieu Marano
Tom Tomlinson
on Feb 18, 2010 at 12:55:42 am
In Theory, I guess you could dub down to a dvcprohd 1400 deck and digitize that.
The 1400 has a cineon gamma correction feature that may work. I don't think its applied to the firewire out, just the SDI.
Thats the only deck that has gamma log features I know.
Good Luck,
TomT
NYC
Tom Tomlinson
Telecine Ass't.
NYC
