Noob question
COW Forums : Sony SRW Decks
Augustine Arredondo
Noob question
on Aug 24, 2009 at 5:25:07 am
Just rented this deck for output and it came set to 23.98 but I need it to be at 29.97. The menu is ridiculously complicated. please help.
cowcowcowcowcow
Mark Spano
Re: Noob question
on Aug 26, 2009 at 1:44:57 pm
It's buried. First, remove any tape from the machine.
Then press SFT and DIAG.
Then SFT and Maint Check.
Then press Others Check.
Then Press System Menu.
F1 changes resolution, F2 changes scan type, F3 changes frame rate.
Set F1 to 1080, set F2 to Interlaced, set F3 to 29.97.
Press F9 to confirm and reboot.
Bill Macomber
Re: Noob question
on Mar 4, 2010 at 6:20:39 am
Mark - thanks - this little piece of info is only posted here as far as I can tell!
