What is possible with this?
COW Forums : Adobe Illustrator
Brooklynn Gay
on May 30, 2018 at 10:53:57 pm
I'm working on creating graphic layouts. And I got into trouble with a large .ai file. Mostly I work in Illustrator, but the recent move from the main place of work made me use cheaper software equivalents. Almost before the order was sent to the client, an incorrect filter overlay occurred, and now objects with an expanded scale appear when the file is opened. I can not edit it, either. there are still big mistakes. I really hope that you will not have to redo the work .
Isaac Murphy
Re: What is possible with this?
on May 31, 2018 at 3:30:12 pm
You can try to create a new document and see how much, if anything, can be rescued if you try to File>Place the damaged one.
You can also try recovering it.
If you don't have "enableContentRecovery", enabled check this
https://helpx.adobe.com/illustrator/how-to/recover-files.html
Help recovering an Illustrator File
http://smallbusiness.chron.com/recover-work-illustrator-39270.html
Illustrator recovery online
https://illustrator.recoverytoolbox.com/online/
