Outer Glow Pixelation on Outlined Font?
COW Forums : Adobe Illustrator
Bob Thompson
on Jan 17, 2018 at 4:51:53 pm
I have an ugly banding/pixelation on an outlined font that I applied an outer glow effect. Does anyone have a remedy so it will be smooth? The attached image is at 300% but it's noticeable at 100%. This is going to be printed on a postcard.
Tom Van Damme
Re: Outer Glow Pixelation on Outlined Font?
on Jan 18, 2018 at 8:10:10 am
Hi Bob,
did you check your "Document Raster Effects Settings" under the Effect menu?
You can set the resolution of your effects to a higher quality - that should do the trick ☺
Cheers,
Tom
Bob Thompson
on Jan 19, 2018 at 3:07:58 am
That did it.
Thank you.
