Interested in recreating this spiral affect
COW Forums : Adobe Illustrator
Chris Charles
on Aug 6, 2017 at 4:17:14 am
Hello everyone,
I'm trying to recreate this spiral effect with 4 letters in a square. The letter starts right side up and gradually shrinks in size as it spirals inward to the center. And in each corner, i guess the direction of the spiral will have to change.
Thank you
Vincent Rosati
Re: Interested in recreating this spiral affect
on Aug 6, 2017 at 8:06:18 am
Start with expanded text.
Make a big M and a little M.
Then do Object > Blend > Make. Then Object > Blend > Blend Options: Specified Steps: 20 or whatever, Orientation: Align.
To achieve the curve, make a path that approximates the spiral, then select the blended text and the new path then Object > Blend > Replace Spine.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
