Specified number of anchor points on shape... (for morphing in AE)
COW Forums : Adobe Illustrator
Christof van Niekerk
on Jun 12, 2017 at 9:46:31 am
Problem:
I have a series of contour shapes (think of map contours) , that I want to animate/morph between in AE.
Problem is... these don't exist as vectors & are traced in Illustrator which yields a range of different anchor point numbers & positions for each shape.
Is there a way to specify more consistent placing ( & number of) anchor points when these shapes are traced... in order to get a more accurate morph/tween in AE?
Thanks for any suggestions/advice up front,
Christof
Vincent Rosati
Re: Specified number of anchor points on shape... (for morphing in AE)
on Jun 13, 2017 at 12:23:08 am
With regard to tracing or altering the number of points...
For an existing object you can Object > Path > Simplify.
For tracing you use custom settings. In earlier versions of Illustrator settings sere available in the Trace drop down menu. Now it has it's own palette under Window > Image Trace.
You can be very precise with these tools. And you can combine results from different tracings, if necessary, when you need to capture different ranges of detail.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
