Pathfinder Problem
COW Forums : Adobe Illustrator
Derek Polson
Pathfinder Problem
on Apr 23, 2017 at 2:42:16 pm
Hi, I usually use the pathfinder to combine objects to a single vector for laser cutting as in Object - Group. Effect - Pathfinder - Add. Object - Expand Appearance.
This has worked for me upto now but it has always been adding a shape to the outside of another shape then combining them.
I want to add a shape to the inside of another shape and then combine them but when I try this the shape inside the other shape disappears.
Any help would be much appreciated.
Vincent Rosati
Re: Pathfinder Problem
on May 17, 2017 at 3:23:03 pm
Not sure I'm clear on the issue.
It sounds like you want a compound path, like the letter 'O', as opposed to a single path, like an 'I'.
You could use - Object > Compound Path > Make.
Or, if the inner object is under the outer object - Pathfinder > Minus Back.
Pathfinder > Exclude.
You may need to use Object > Arrange > ... to get the objects in the the proper layering order.
*Please remember to Like an answer if it solves your question or gives you a good idea.
© 2018 All Rights Reserved
