Copying by size
COW Forums : Adobe Illustrator
Dlwoad Forjnig
Copying by size
on Apr 18, 2017 at 12:32:32 pm
I need to make some texture with circle in circle and I did it manually, but I would love to know how to make that process a little bit faster. I'm sure illustrator has feature for this but I didn't find.
Kevin Phillip
Re: Copying by size
on May 18, 2017 at 12:03:17 am
You can do that with the Blend Tool (w). Create the largest and smallest circles. Select both circles. Double click the blend tool, select specified steps, select the number of intermediate circles you want by indicating the "specified steps". click on one of the anchor points on one of the circles, then click on the same/corresponding anchor on the other circle (i.e., click the top anchor on both).
If that doesn't make sense, look up using the blend tool on YouTube for clarification.
I hope this helps.
© 2018 All Rights Reserved
