Select layers with same name?
COW Forums : Adobe Illustrator
Greg Howell
on Feb 9, 2017 at 10:08:08 pm
Hi all,
Here's my problem...
I have several hundred symbols as sublayers in layer 1. All the symbols are either Symbol 1's, Symbol 2's or Symbol 3's. I want to split all the symbols into just 3 layers (layer 1 for symbol 1's, layer 2 for symbol 2's etc..) The thing is, is there all mixed up. How to I select all Symbol 1's so i can move the layer order without having to go through and select each one individually?
thanks in advance.
Greg
Vincent Rosati
Re: Select layers with same name?
on Feb 11, 2017 at 3:33:59 pm
Select a symbol and try..
Select > Same > Symbol Instance.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
Vincent Rosati
on Feb 11, 2017 at 3:38:50 pm
Also, once an item or items is selected, in the Layers palette, a selected item indicator appears on the right side of the layer. It's a small colored square. You can click and drag this indicator to the desired layer. This will move all items that are currently selected.
Vince
