Tapered ZigZag
COW Forums : Adobe Illustrator
Matthew Beall
Tapered ZigZag
on Jan 31, 2017 at 7:44:46 pm
I have a spline with a zigzag distortion on it, but I want the effect tapered so it starts as a straight line and then gradually zigzags. How do I do that?
Vincent Rosati
Re: Tapered ZigZag
on Feb 24, 2017 at 12:59:52 am
I realize you may have resolved this already, but I'm just seeing it now.
11068_effectandenvelopetopobjectdistort.ai.zip
The included steps are:
1 - Start with a standard, straight, 2-point path.
2 - Apply Effect > Distort > Zig Zag.
3 - Create a "Top Object" in the shape of a triangle, that is the desired shape of your taper. Again, a basic shape, 3-points, no curves.
4 - Make sure this top object is layered above the zig zag, then select both the zig zag and the top object and Object > Envelope Distort > Make with Top Object.
Then add an additional path to the tip as needed.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
Matthew Beall
Re: Tapered ZigZag
on Feb 24, 2017 at 3:24:23 pm
Thank you Vince!
I had NOT figured that out yet, in fact I had made the necessary splines in 3DSMax as a quick fix..!
This helps a lot, thank you
