Merging two non-overlapping shapes in Illustrator CC
COW Forums : Adobe Illustrator
Tine Korsic
on Jan 26, 2017 at 2:58:06 pm
Greetings,
as the titles says, I'm having issues with joining two shapes which do not overlap in Illustrator CC.
Explanation in the screenshots:
For example, I would like to merge the two objects selected, in the top-left http://prnt.sc/e0mdy2
The thing is, those two object do not overlap, as seen when I move the inside object out http://prnt.sc/e0mgk9
Anyways, the outside shape is not a stroke http://prnt.sc/e0mhab
Any help would be appreciated.
Vincent Rosati
Re: Merging two non-overlapping shapes in Illustrator CC
on Jan 27, 2017 at 12:05:50 am
Select both objects and use Pathfinder > Unite.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
Tine Korsic
on Jan 27, 2017 at 7:30:55 am
Thanks for the swift answer but I've already tried that. and that's what happens:
http://prnt.sc/e0x2dt
http://prnt.sc/e0x2pl
The whole rectangle around the objects turns into the fill color. I have no idea why.
Please help.
Tine Korsic
on Jan 27, 2017 at 7:45:05 am
Update - I think it has something to do with the clipping masks. Is there a way to convert them into objects?
btw, I'm pretty new with Illustrator, therefore I apologize for dumb questions.
Vincent Rosati
on Jan 28, 2017 at 12:24:49 am
Hmmm. Could be.
A few other things to try first..
Object > Expand, then try Unite.
Or, as you suspect, Object > Clipping Mask > Release, then Unite.
If you can't get it to work, consider uploading the file and we'll fix you up.
Vince
