Can you specify an angle to rotate/skew, but around a different reference point?
COW Forums : Adobe Illustrator
Sam Yost
on Oct 1, 2016 at 9:35:54 pm
When you use the skew or rotate menus, the reference point is always in the center. Is there a way to specify a different reference point and then say "rotate" by X degrees? I do this action a lot and it's really annoying to always drag-rotate around the point until I've got it juuuuuuust close enough with the angle counter on the cursor.
Vincent Rosati
Re: Can you specify an angle to rotate/skew, but around a different reference point?
on Oct 1, 2016 at 9:45:28 pm
Have you seen this...
https://library.creativecow.net/articles/rosati_vincent/radial_patterns.php
You might also be able to record an action, depending on your exact situation.
Vince
*Please remember to Like an answer if it solves your question or gives you a good idea.
