Adobe Illustrator error.
COW Forums : Adobe Illustrator
Herbert Clay
on Aug 12, 2016 at 8:05:49 pm
Greetings!
I have created Illustrator .ai file 2 month ago and then saved it. Now when trying to reopen the file I get the error message: Adobe Illustrator error
Is there a way to make adobe illustator repair?
Thanks an advance.
Kalle Kannisto
Re: Adobe Illustrator error.
on Aug 13, 2016 at 5:36:17 am
https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-fil...
Kalleheikki Kannisto
Senior Graphic Designer
Herbert Clay
on Aug 15, 2016 at 8:18:13 pm
Hello Kalle Kannisto,
Thanks for reply
Rex Payne
on Aug 18, 2016 at 4:50:54 pm
Hi Herbert Clay.
First of all try to open it in the Acrobat reader. If it useless your file is corrupted.
If you need to repair your file then download, install and start Illustrator Repair Toolbox. It can fix other errors also:
Can’t open the illustration.
Download it here: https://www.repairtoolbox.com/illustratorrepair.html
Best regards
Herbert Clay
on Aug 19, 2016 at 5:34:17 pm
Rex Payne
Thank you. this tool is helpful
Herbert Clay
on Sep 12, 2016 at 8:45:50 pm
For adobe illustrator repair this tool is the best solution!
