Path offset problem
COW Forums : Adobe Illustrator
John Daren
Path offset problem
on Aug 11, 2016 at 1:37:31 pm
Hi, I'm trying to make my image 0.1mm larger. When I select it and go to Object>Path>Offset Path, I can create the offset. The problem is that it creates a negative path as well as a positive path. How can I just have the positive (outside, expanding) path?
The object is a simple square, which is completely closed
John Daren
Re: Path offset problem
on Aug 11, 2016 at 8:54:12 pm
I found the answer. The file was exported from Solidworks. It needed to be released from a compound path, and then 'joined' first.
