Masking object inside outline type
COW Forums : Adobe Illustrator
Joe Bodego
on Jul 24, 2016 at 10:05:32 am
Hello, i have a series of lines that i would like to mask inside type that was converted to outline. How is this done, i tried but only one character of the type would mask. When i group all i get is a white background. Help!!
Vincent Rosati
Re: Masking object inside outline type
on Jul 25, 2016 at 12:23:12 am
Select all of the expanded text and Object / Compond Path / Make, then it will work as expected, as a single clipping mask.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Joe Bodego
on Jul 25, 2016 at 7:31:04 am
Thank you so much, that worked out, a thousand thanks
