Clipping Art - not sure what to do
COW Forums : Adobe Illustrator
Joel Aarons
on May 24, 2016 at 1:37:08 am
I have some art on Illustrator made up of multiple shapes. I want the three rectangles "clipped" so that they only exist as part of the purple rectangle (if that makes sense). I'm sure it's possible, but haven't figured out how.
<a href="https://images.creativecow.net/310513/pic.jpg"><img src="https://i1.creativecow.net/u/310513/pic.jpg" border="0" /></a>
Vincent Rosati
Re: Clipping Art - not sure what to do
on May 24, 2016 at 3:15:08 pm
You probably want to use Object / Clipping Mask / Make - Where a copy of the purple shape is the clipping mask.
On the purple shape..
Use Copy, Paste in front (Cmd + C, Cmd + F).
Then Bring to front (Cmd + Shift + ])
Next, with the new purple shape selected, shift-select one of the other internal shapes, or all of them, and make a clipping mask.
You can search the forum for Clipping Mask for more info.
You could alternatively use a Pathhfinder approach. Instead of masking the shapes, you can cut them to the precise size.
Do a search for Pathfinder, here on the forum, if that sounds like something you're interested in.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Joel Aarons
on May 24, 2016 at 10:24:08 pm
Fantastic! The clipping mask is exactly what I needed!
Thank you!
