Scaling rounded corners?
COW Forums : Adobe Illustrator
Jerry Smith
on Apr 17, 2016 at 8:19:36 am
I have a complex path. Outside is a path drawn with the pen tool. In side are rectangles with rounded corners that I made with the rectangle tool. These were created with the settings on points rather than pixels and they are pretty small. Maybe 8 pixels across. When I go to transform and scale up, everything scales as it should except the rounded corners which get smaller and smaller relative to the rest of the compound path. What did I do wrong? How do I fix it? Thanks in advance.
Kalle Kannisto
Re: Scaling rounded corners?
on Apr 17, 2016 at 8:21:44 am
Alt-click on the scale tool, it gives you the scaling options. Select "scale rectangle corners".
