Trying to make a fillable design!
COW Forums : Adobe Illustrator
pat jts
on Feb 26, 2016 at 1:28:32 am
I am trying to make this shape and want it to be fillable:
enter image description here
(file can be dowloaded here: as pdf or in Illustrator).
I know Photoshop a little bit, Illustrator far less! I'd like this to be vector, so in Illustator.
I made a path and then applied the brush. Then I reflected it. However, I realize now that I have to do it all over again, and the proper way - which I don't know what it is and I know it is fairly simple - because it has to be transparent - fillable.
What is the proper way to do this?
The other problem with this is, that up top there forms two triangles, one on each side, as a result of the reflection and combining of two sides. Likewise, on the sides where the curve meets the straight line, I need a smooth path, no crick that shows that join.
When I put this pdf in illustrator, I can't make much sense how to use the pen tool to outline also how to replicate the double curves one beneath the other. Basically need to re-do to be fillable, using this as a template. Would love your help as soon as possible. Thank you so much!!
© 2018 All Rights Reserved
