Convert drawing into colorable objects
COW Forums : Adobe Illustrator
Heidi Lindsay
on Jan 1, 2016 at 10:06:44 pm
Hi, I have a grid with interlocking sine waves over it. It's for a quilt, and I want to be able to color each slice differently so I can see how the colors work together. How do I change the shapes into colorable objects? I can upload an image, but what file types are acceptable? Thank you!
Vincent Rosati
Re: Convert drawing into colorable objects
on Jan 2, 2016 at 3:50:29 am
You could potentially use the Live Trace feature. Select the image, click the Live Trace dropdown menu and choose Tracing Options. Adjust settings. Trace. Then Object > Expand.
You can now access all of the parts with the selection tools.
Depending on the pattern, you might just want to open the image with Illustrator and redraw it as a vector.
If you ever need to upload an image, you should use JPG or PNG, but you can also upload files of any type. Just make sure to attach them to the message, it doesn't happen automatically.
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
© 2018 All Rights Reserved
