.ai file in Adobe Illustrator 10
COW Forums : Adobe Illustrator
herro leandro
on Nov 19, 2015 at 11:55:22 pm
When I tried to open the .ai file in Adobe Illustrator 10, it displayed an error which states, " Adobe Illustrator file format is having difficulties "
What should I do for the problem?
Vincent Rosati
Re: .ai file in Adobe Illustrator 10
on Nov 20, 2015 at 4:17:35 am
https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-fil...
Some people have solved this by ensuring that the file and all parent folders have read/write permissions.
If you can open the file, copy the art into a new project file.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
Renan Linhares
on Nov 22, 2015 at 8:01:31 pm
There may be a TMP file in the same folder, you can try renaming it to AI and see if this opens. Helped me on a couple of occasions but also has not worked in the past. If it useless, there is a good program: Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
