How to Create this Look
COW Forums : Adobe Illustrator
Erica Reichard
on Aug 30, 2015 at 3:51:27 pm
I cannot figure out how to create the loop in the letter B as shown in the example image attached. I want to create a similar look with it looped/threaded around the letter T in my case.
Any suggestions?
Vincent Rosati
Re: How to Create this Look
on Aug 31, 2015 at 1:25:01 am
Please see the attached project file...
Delete Structure with Pathfinder project file >>
The steps listed in the project file are:
1
Live text.
2
Type > Create Outlines.
3
Add a stroke and increase weight in Stroke palette
4
Select the stroked object and Object > Expand
5
Use the Group Select tool to select the outer edge of the stroke. Then Copy, Delete. Edit > Paste In Back.
6
Use the Group Select tool and shift-select the T and the back object. Then Effect > Pathfinder > Minus Back.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
